Thread: Audio output (Denon AVR-2307Ci) |
New member Username: Jkslifer
Post Number: 1 Registered: Aug-09
| Posted on Sunday, August 09, 2009 - 07:27 pm: |
I have Denon AVR-2307Ci and having problem with my audio output from my TV. Everything had been working fine for two years, but now ran into an issue in which my TV audio is not working. My DVD and Stereo receiver work fine, but when I switch my receiver to TV, I’m no longer receiving sound. Any suggestions? |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 850 Registered: Feb-08
| Posted on Monday, August 10, 2009 - 06:41 am: |
Greetings, How are all of your components connected? It certainly does seem odd that the operation of your system changes in mid stream like that. |
Post Number: 2 Registered: Aug-09
| Posted on Monday, August 10, 2009 - 07:01 am: |
TV is connected through HDMI, stereo is two zone with 5 speakers hooked up to it for the main room and then i have other speakers hooked up for two other rooms. Both the DVD player and cable receiver are hooked up directly to the stereo. |
Michigan
Post Number: 851 Registered: Feb-08
| Posted on Monday, August 10, 2009 - 07:18 am: |
Sorry, I must be a little slow this morning! Is this correct? HDMI from cable box to TV. HDMI from DVD player to TV. Audio from cable box to receiver (what is the connection type, RCA analog? optical or coax digital?). Audio from DVD player to receiver (again, what kind?). If possible, swap the audio to the receiver between DVD and TV and see if your situation changes any. If it does (the TV works and the DVD does not) then it is likely that a setting on the receiver has changed and needs to be adjusted properly. This setting most likely would be some sort of "input" as in digital or analog. More detail is possible given the connection method and the receiver make/model. |
Michigan
Post Number: 852 Registered: Feb-08
| Posted on Monday, August 10, 2009 - 07:20 am: |
Oops, I AM slow this morning! The make/ model has already been given in your header, sorry! |
Post Number: 3 Registered: Aug-09
| Posted on Monday, August 10, 2009 - 11:22 am: |
HDMI from cable box to TV and HDMI from receiver to cable box. No audio from cable box to receiver (never had wires here). I did just try using regular RCA wires in seeing if this would add audio, but nothing. My DVD player has regular RCA wires from DVD player directly to the receiver. My TV is 12 feet away and need to purchase RCA wire to try what you suggested. Now that you understand my confiq, any other suggestions? |
Michigan
Post Number: 853 Registered: Feb-08
| Posted on Monday, August 10, 2009 - 02:04 pm: |
My suggestion would be: HDMI from cable box to receiver HDMI in 1. HDMI from DVD player to receiver HDMI in 2. HDMI from receiver out to TV. If your DVD player does not have HDMI this receiver should be capable of upgrading the component video input out of the DVD player in to Comp 1. Audio would then be handled via either Coax-1 in or Opt-1 in. Is ether of these set ups possible? |
