Thread: Digital optical audio out on TV question. |
New member Username: Cypherxr
Post Number: 1 Registered: Jul-09
| Posted on Sunday, July 26, 2009 - 12:48 pm: |
Hello, I'm new here so please bear with me. My old Toshiba DLP finally lost it's light engine this past week so I'm planning on purchasing a Panasonic Viera TC-P54S1 54" Plasma TV next week. Upon further inspection the only audio output on the back is that of an optical digital audio output. Previously with my old TV, I had RCA cables running from audio out into my receiver. As in, I had my gaming systems hooked up through a selector box, with the output of that running into my TV. I also have DirecTV HD going through HDMI, my PC going through HDMI and my PS3 going through HDMI. My receiver does have a digital audio input on the back but I've never really messed around with it much. What my question essentially is, if I hook the TV's digital out to my receiver's digital in, will I be able to hear sounds from all the sources plugged into the TV (gaming system's through selector box, component connections and HDMI connections?) Thanks in advance for any help or advice that is given. |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 844 Registered: Feb-08
| Posted on Sunday, July 26, 2009 - 01:08 pm: |
Short answer: yes! Long answer: your connection method may not be the best but if you are switching all of the components with the TV and a switch box (as opposed to using the receiver) then an optical should work. |
Post Number: 3 Registered: Jul-09
| Posted on Sunday, July 26, 2009 - 06:17 pm: |
Ok, thank you. What method would be best for the setup I have? I do want the best sound quality I can get. |
Michigan
Post Number: 845 Registered: Feb-08
| Posted on Sunday, July 26, 2009 - 06:41 pm: |
Ideally you would have an audio receiver capable of switching all of your HDMI devices. Assuming that your receiver does not have this capability your method using an optical cable will have better audio than you did before. |
Post Number: 4 Registered: Jul-09
| Posted on Sunday, July 26, 2009 - 06:46 pm: |
Yeah, my receiver only has one optical audio input, so I guess I'm stuck huh? |
Michigan
Post Number: 846 Registered: Feb-08
| Posted on Sunday, July 26, 2009 - 06:51 pm: |
I wouldn't say that you are necessarily "stuck". Let's just say it is your best option at this moment Enjoy! |
