Thread: Sony 522 XBR /Yamaha RX V 1800suggestions |
New member Username: Rpmsanders
Post Number: 6 Registered: Dec-08
| Posted on Wednesday, June 24, 2009 - 07:45 am: |
Hi Guys, I currently have a Sony 52" XBR and Yamaha RX V1800 amp fed by a PS3 for Blu Rays and a Bose Acoustimass 10 surround system. Far from being an expert I hooked the system up myself and essentially followed the manufacturers suggestions. My question is, are there any "tricks" or other settings that anyone has found that works well. I'm not unhappy with anything but I'm sure with so many options that some fine tuning will help. Also, does anyone get an "expert" in afterwards to check their connections are also correct? Thanks in advance everyone, Cheers Mark |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 841 Registered: Feb-08
| Posted on Wednesday, June 24, 2009 - 08:01 am: |
Greetings Mark, I sure wish you would have asked for advice prior to your purchases but, as they say, better late than never. The "trick" with any system tuning is getting it right for YOUR eyes and ears. An "expert" can set it up to "spec" but that NEVER means it is set up "correctly". Ideally the "correct" setting occurs when the user understands the limitations (highs, lows, balances, fades, surround modes, speaker placement, room acoustics, volume, and all of the source settings) of the system and has it all set to a level that thrills them every time they turn it on. |
