Home > Message Board > Home Theater > Home Theater Setup & Planning > New set up
Author Thread: New set up
Username: Ezeek
Hello, I'm looking @ purchasing the Difinitive Technology home theater system. With the supercube sub do i need a receiver?
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 818
Yes,
Definitive Technology does not make amplifiers as far as I know.
http://www.definitivetech.com/Products/HomeTheater/OnShelfSystems.aspx
http://www.definitivetech.com/Products/HomeTheater/FloorStandingSystems.aspx
Username: Ezeek
Even though the sub is powered?
Username: Jrbay
Post Number: 819
Yes, for sure Eric.
A powered sub is the 0.1 of a 5.1 or 7.1 speaker system. The point 1 designates the sub as active (as opposed to a non-powered passive sub).
The remaining 5 or 7 speakers are going to need an amplified signal.
Username: Cclashh
Post Number: 404
Hi Jim..
Eric,
You would know if these systems were a full package or not. Its pretty obvious that they are only selling the speakers and nothing else. The receiver would be listed right along with the speakers if the packages came with one. You would not have to figure it out. Yes you would need a receiver to go along with the packages you are looking at as speakers are not much good without one. You can get what is called a Home Theater in a Box if you want everything in one package but that is not what you are looking at right now.
Username: Ezeek
Hey guys thanks for the info. Much appreciated!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > New set up [ « Previous ] [ Next » ]
