Home > Message Board > Home Theater > Home Theater Setup & Planning > Mounting my LCD!
Author Thread: Mounting my LCD!
Username: Erikmj
I am looking for a product I can use to bring power to the back of my Plsma TV I am mounting. I just did some searches on the net and I found this Datacom product. http://www.cablegiant.com/Default.aspx?p_id=4&Product_id=963
Has anyone every used this product or are you aware of another option that is better recommended for Do It yourselfers like me to mount my TV? ? Any help is appreciated!
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 810
This look to be a very nice package and also looks like it will work very well for your project. Without any intention to offend I am guessing perhaps that electrical work isn't something you have done too much of and if this assumption is correct I would say that this is the way to go.
You certainly won't get an electrician to wire it up for less.
Username: Erikmj
Thanks for your input. I actually found a How To Video on YouTube that shows how to use that Datacomm product and help me with my install.
http://www.youtube.com/watch?v=OAu-GRkNLao&feature=channel_page
I will report back after and let you know how my install went! Whish me luck!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > Mounting my LCD! [ « Previous ] [ Next » ]
