Thread: Center Hookup |
New member Username: Lokeyq7
Buffalo,
NY
Post Number: 8 Registered: Mar-09
| Posted on Friday, April 03, 2009 - 10:08 pm: |
Gentlemen (and ladies), I know this should be simple enough. However, I am running into a problem with the hookup of my B&W HTM61 Center Channel hookup. I have it biwired to my Yahmaha v663 A/V and Bryston Amp. However, I am not getting any isolated sound from the center channel. Can anyone advise on what I am doing or not doing right? |
Bronze Member Username: Mike19
Tallahassee,
Fla
Post Number: 14 Registered: Jan-09
| Posted on Saturday, April 04, 2009 - 09:16 am: |
Hi Sherman. I recommend: First, on your receiver, make sure you have the center channel to "on" and with sufficient volume level. If that doesn't do it, try undoing the bi-wire connection and use a sinlre wire connection instead. Mike |
Buffalo,
NY
Post Number: 9 Registered: Mar-09
| Posted on Saturday, April 04, 2009 - 09:42 am: |
Ok. However, I know that the center channel is on because it works fine when I switch over to Satellite T.V. The only time I really do not hear much of anything from my center is when I am playing DVD/CD's through my Escient system. I am wondering if I need to run a A/V cable from my Escient to the receiver. I already have audio coming through my fronts when playing movies or CD's through the Escient. Those are connected through component cables and audio. This really has me stumped. I have even noticed that even though sound comes out fine on the center when watching satellite T.V. it almost seems at though my fronts start working like rears. However, I know that is not the case. I guess I just have to keep playing around with it. |
Bronze Member Username: Lokeyq7
Buffalo,
NY
Post Number: 11 Registered: Mar-09
| Posted on Tuesday, April 07, 2009 - 12:30 pm: |
I resolved my center channel issue by using coaxial cable. Now hear isolated audio from the center channel. But I have lost audio from the internet radio. When I remove the coax the internet radio audio comes back. I have contacted Escient to inquire about hookups. |
