Home > Message Board > Home Theater > Surround Sound > No digital inputs on surround sound r...
Author Thread: No digital inputs on surround sound receiver
Username: Dmehling
Post Number: 16
I purchased several years ago a receiver with six analog inputs for surround sound. But I only used it for stereo sound and never hooked up additional speakers. Now I want to use it for surround sound, but my new HDTV of course only has a digital output for sound. Is there any method or device I can use to get surround sound on my receiver from my TV?
Username: Mike19
Tallahassee, Fla
Post Number: 15
Hi Douglas.
"Is there any method or device I can use to get surround sound on my receiver from my TV?"
Not that I know of. Maybe its time for a new reeiver.
Mike
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 778
Greetings,
You should be taking your TV sound from a STB (Set Top Box, either cable or satellite) which is most likely going to have the analog outputs you need.
Username: Dmehling
Post Number: 17
I don't use satellite or cable
Username: Jrbay
Post Number: 784
If you live in the States then you will need a STB once the digital conversion takes place in June. From this you can take your audio, if not then an old VCR could help you out.
Username: Dmehling
Post Number: 18
I don't think you understand. I have a high-definition TV. I am currently only watching digital broadcasts so I do not need a converter box. I'm trying to figure how to get 5.1 surround sound not standard two channel audio which would not be a problem if that's all I wanted.
Username: Jrbay
Post Number: 785
A DVD recorder or something to this effect:
http://www.antonline.com/p_GTV-AAUD-2-DIGAUD-NX_538683.htm
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Surround Sound > No digital inputs on surround sound r... [ « Previous ] [ Next » ]
