Home > Message Board > Home Theater > Home Theater Setup & Planning > Question about audio out choices
Author Thread: Question about audio out choices
Username: Mrmizmo
Hi I have my home theater set up and audio connected via digital audio out, my question is I'm not sure what a optical audio out is...I have ports for this but was wondering if it made a difference or should I just leave it be.
Thanks
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 769
The orange digital coax and the fiber optic Toslink connections both carry the same signal. You will not notice the difference between the two.
Is that what you needed to know??
Username: Mrmizmo
Thank you Jim thats what I needed to know
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > Question about audio out choices [ « Previous ] [ Next » ]
