Home > Message Board > Home Theater > Home Theater Speaker Packages > 5.1 on a budget
Author Thread: 5.1 on a budget
Username: N2audio
Lawrence, Ks
Post Number: 1728
Hi -
After 10 years of procrastination my dad is finally finishing the basement and wants to incorporate a 5.1 sound system. I've been asked to do the leg work.
I THOUGHT he'd just want some 200-300 all in one package from BB, but apparently the budget is in the $500-700 range so I figured I could come up with something pretty decent.
Primarily used for movies, but occasionally some music. Won't ever be played very loud.
The only catch is I need the 2 surround speakers to be wall/ceiling mount -
Parts Express has some Dayton's for $60 that look ok, or I found some Audiosource's on ebay for $42. I'm not going to spend much on surrounds.
Fronts - not sure. A couple hundred maybe?
I came across these (Cadence is a respected name in car audio)
http://cgi.ebay.com/CADENCE-SOUND-SYSTEMS-F-17-FRONT-STAGE-SPEAKERS_W0QQitemZ310 125784312QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item310125784312&_trksid=p3 286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1309%7C301%3A 1%7C293%3A1%7C294%3A50
A step better?
http://cgi.ebay.com/Cadence-F19-Home-Theater-Music-Speakers-New-in-Box_W0QQitemZ 310122604097QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item310122604097&_trksid =p3286.c0.m14&_trkparms=72%3A1234%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1309%7C301 %3A1%7C293%3A1%7C294%3A50
Other ideas?
Sub - doesn't need to be fancy. I'm leaning toward one of the $100-150 10's that are regularly on ebay: http://cgi.ebay.com/400W-New-10-Inch-Home-Theater-Sub-Acoustic-Audio-RW-NR_W0QQi temZ120383583971QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item120383583971&_tr ksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
That only leaves me $300 or so for a center channel AND a receiver. For my own system I bought one of the <$50 DIY kits from mavin.com and I've been pretty happy with it. I could go that route.
What about the receiver? What's the best bang/buck going?
Username: John_s
Columbus, Ohio
US
Post Number: 2443
Here's a good low priced receiver.
http://www.hometheatermag.com/receivers/808piorec/index.html
As low as $220.
http://www.bhphotovideo.com/c/product/539194-REG/Pioneer_VSX_918V_K_VSX_918V_K_5 _1_Channel_A_V_Receiver.html
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Speaker Packages > 5.1 on a budget [ « Previous ] [ Next » ]
