Home > Message Board > Home Theater > Home Theater Setup & Planning > How to set up sound for Tv
Author Thread: How to set up sound for Tv
Username: Luciusreal
Hey everyone I went out today and brought a LG Wireless Home Theater HT903WA With a LG 42 HD 100Z Plasma 42PG20D, I have set it up with a HDMI connection, and no other cords, I would like to use my tv with the surround, what cables do i need to connect from the tv to the Lg Wireless theater, I have Rca Cords, I did look in the manual and there was a option explaining if I had a Optical cord I could just use that ,though i don't have one at this time. any help would be great full.
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 705
Greetings James,
What is your TV source? A cable box or satellite box? If so, take the audio, preferably digital from that.
Hey Jim
Thank you for the quick reply, Im not using any Tv source provided what i plug into the wall, i am located in australia.... Sorry if i couldnt be of any more help But i belive the problem is that i need to get a optical cord to plug into my tv to dvd player
Username: Jrbay
Post Number: 706
Is there any analog (RCA red/white) output from the TV? That would work just fine and perhaps even better than the optical out. IF the optical is the only audio output (many time the case) then yes, you will need an optical cable.
Hey Thanks heaps for your help, I connect the Rca from the dvd the Red and white cords, put it on Aux and everything worked fine, thank you for all the help...
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > How to set up sound for Tv [ « Previous ] [ Next » ]
