Home > Message Board > Home Theater > Home Theater Setup & Planning > Echo sound problem: LG LH T9656 + LG3...
Author Thread: Echo sound problem: LG LH T9656 + LG30 series TV
Username: Itemboleh
Hi,
I've just upgrade my TV from Samsung 29" to 32" LG30 Series TV. The reason i'am doing this because i want bigger LCD and also i already have home theater LG LH T9656.
But surprisingly i am very disappointed. The sound of tweeter speaker are automatically replaced by the sound from TV speaker and the bad thing is, the sound from TV speaker and the sound from home theater speaker are not synchronize. The delay between them produce the sound similar to echo sound.
The same problem not occurred before when i used samsung TV (tweeter speaker was working).
Please help me, are there any explanation regarding this? is it a bug of LG product or there are some configuration that i need to do. As additional info i connect the TV and HT using HDMI and also component.
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 695
There is no reason to have your TV speakers working at the same time as you Home Theater system. Turn off the TV speakers and you problem is solved.
Username: Itemboleh
Hello,
If i turn off the TV speakers i couldn't get full 5.1 sound working as tweeter speaker doesn't produce any sound.
I am sure no problem with tweeter speaker and i already test it by radio and also test function from menu.
It seems the sound of tweeter replaced by tv speakers. This problem not occured when i am still using samsung LCD TV.
Username: Jrbay
Post Number: 700
I am sure this is my fault but I am not sure I understand a couple of things here. First off what is meant by "tweeter speaker"? (Tweeter is a term used for the high frequency driver of a 2 or 3 way [generally] speaker system).
Secondly how do you have this system wired where you need to use the TV speakers?
If installed as is intended a Home Theater package (HTiB) such as your LG I believe should not make any use of the TV speakers at all.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > Echo sound problem: LG LH T9656 + LG3... [ « Previous ] [ Next » ]
