Home > Message Board > Home Theater > Home Theater Setup & Planning > Speaker placement 7.1
Author Thread: Speaker placement 7.1
Username: Steve139186
Hi, i have a room thats about 18x11x and 8 feet in the rear and it climbs to 11 feetwhere the tv sits. my problem is this I have build three row of seats..5,4,3 and it sits 14" in the back drops 6" then drops 5" so the front 3 seats are only 1" off the ground how do i postion the two side surrounds? most say 90 degres from the center channel but it is 90 from the middle row, or mabey more foward then pointed slightly down and to the rear, need help guys??
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 681
Greetings Steven,
See if this helps you any then just let your ears do the work for you!
http://www.customconnectionsonline.com/faq4.html
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Setup & Planning > Speaker placement 7.1 [ « Previous ] [ Next » ]
