Thread: "Small" setting in STR-DE595 Sony Receiver |
New member Username: Robmlisanti
Ossining,
New York
Post Number: 1 Registered: Feb-07
| Posted on Tuesday, February 03, 2009 - 04:11 pm: |
Does anyone know for a "fact" what the small setting in then sony DE series is set at in Hertz? 80hz?...120hz..I'm trying to get my Velodyne VX-10 Sub to blend good with my receiver. |
Bronze Member Username: Onecall
Spokane,
WA
Post Number: 64 Registered: Dec-08
| Posted on Wednesday, February 04, 2009 - 12:35 pm: |
Hi Robert, Unfortunately Sony does not list in their manual what the crossover frequency is for the subwoofer output. With your VX10 sub your best option will be turning the crossover dial as high as it will go. That way the crossover in the subwoofer will not filter out anything the receiver would be sending to it and should give you the best blend with your speakers. I hope this helps, let me know if you have any questions. Matt @ OneCall |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 682 Registered: Feb-08
| Posted on Wednesday, February 04, 2009 - 03:07 pm: |
http://customconnectionsonline.com/faq5.html http://customconnectionsonline.com/faq6.html |
