Thread: True HD Dolby Digital, DTS |
Silver Member Username: Monkey_man_jack
Santa Maria,
California
United States
Post Number: 529 Registered: Dec-04
| Posted on Wednesday, January 07, 2009 - 03:03 am: |
can you only listen to the True HD Dolby D using the Pre out? I'm 98% sure on this but not 100% positive. I would assume as much since i cant hear anything through optical |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 628 Registered: Feb-08
| Posted on Wednesday, January 07, 2009 - 06:53 am: |
Optical from what? |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 571 Registered: Jun-05
| Posted on Wednesday, January 07, 2009 - 01:43 pm: |
Dolby Digital TrueHD will not be sent through an optical wire. "If the Blu-ray player will decode Dolby TrueHD and DTS-HD Master Audio to PCM for output via HDMI to an AVR or pre/pro.Additionally, the 192kHz/24-bit digital-to-analog audio converters to decode and output all audio formats from its 7.1/5.1 analog outputs" |
Santa Maria,
California
United States
Post Number: 533 Registered: Dec-04
| Posted on Wednesday, January 07, 2009 - 02:26 pm: |
so a PS3 cannot put out trueHD, i need a separate Blu-Ray player |
Michigan
Post Number: 629 Registered: Feb-08
| Posted on Wednesday, January 07, 2009 - 03:46 pm: |
A PS3 should output trueHD via HDMI |
New member Username: Tes918
Houston,
TX
United States
Post Number: 1 Registered: Feb-08
| Posted on Wednesday, January 07, 2009 - 09:30 pm: |
So without HDMIyou need to feed 7.1 analog to the pre/pro or receiver that can accomodate 7.1. What is your recommendation for a blu-ray player that is best for 7.1 |
Santa Maria,
California
United States
Post Number: 537 Registered: Dec-04
| Posted on Thursday, January 08, 2009 - 12:35 am: |
my receiver was at the dawn of surround sound, thus having no HDMI inputs..... it's not quadraphonic...haha, but it is old... it does have the 7.1 input on it though. so apparently i need an upgrade |
BREEZY POINT,
NY
Post Number: 575 Registered: Jun-05
| Posted on Monday, January 12, 2009 - 02:06 pm: |
The Panasonic DMP-BD55K or the Sony BDP-S550 both have 7.1 anolog out puts. Both list for 399.00. I find my self needing one of these machines and will begin to shop in Feb. As the new models were introduced this past weekend in Las Vegas. |
New member Username: Steve139186
Post Number: 2 Registered: Feb-09
| Posted on Tuesday, February 10, 2009 - 01:36 am: |
If your using av reciever the does 7.1 or your just doing 5.1 i would reccomend panasonic DMP -BD35k instead of 55k. only real difference is 5.1 instead of 7.1 but 35 is around 150$ less |
