Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Setting up my room
Author Thread: Setting up my room
Username: Dupe112309
Post Number: 93
I have a 42" 1080p panasonic plasma, a comcast hdtv cable box, and a 5.1 panasonic surround sound. I thought I'd be able to connect the hdtv cable box to the surround sound but the surround sound only has an hdmi out. Is there a way I connect only audio to surround sound then to tv?
Username: John_s
Columbus, Ohio
US
Post Number: 2412
If all you have is HDMI out, then the answer is no.
I do find it hard to believe that you have no other input/output jacks available on your system.
Post Number: 94
it's not that I dont have any other jacks, it's just that I only have an HDMI OUT for HDMI, could I run HDMI from my 360 and hd cable box to the tv, then run audio from the 360/cable box to the surround sound?
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 590
That should resolve your issue!!!
Post Number: 95
so I'd prob have something like my input 1 would be my for my tv sound and then my input 2 would be for my xbox 360, right?
Username: Jrbay
Post Number: 593
Correct, that would probably be the easiest to remember.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Setting up my room [ « Previous ] [ Next » ]
