Home > Message Board > Home Theater > Surround Sound > Surround Sound Works Only with DVD
Author Thread: Surround Sound Works Only with DVD
Username: Seanbanks
Hello,
I have a Toshiba Home Theater DVD (http://www.tacp.toshiba.com/hometheater/product.asp?model=sd-43ht). Anytime I have played a DVD, the surround sound works just fine.
I recently bought a Samsung LCD TV (http://www.samsung.com/us/support/download/supportDown.do?model_nm=LN-T3242H&mTy pe=EM&vType=L&disp_nm=LN-T3242H).
I'd like to be able to use the surround sound when I'm not watching a DVD though. Any help would be greatly appreciated.
Best,
Sean
Username: Seanbanks
I knew it was an easy answer. I got it. Just put the Audio Out from the TV to the Audio In on the DVD. Switched the function on the DVD to AUX1 and we were good to go.
Thanks anyway.
Username: Vm8444
Post Number: 43
what is your tv source cable ?
satellite,,
is there a reviever involved to change channels or is the tv only used to change channels then whats your reciever then?
vince
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Surround Sound > Surround Sound Works Only with DVD [ « Previous ] [ Next » ]
