Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Connecting stereo system to tv with o...
Author Thread: Connecting stereo system to tv with optical digital audio cable
Username: Deltaiscain
Hello, i have a question. I recently bought a LG hd tv, and a samsung cinema system. Can i listen to my tv on the samsung system by connecting it with a optical digital audio cable? These are also called TOSLINK cable's.
Thanks a lot
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 562
You can but it would be better to take the audio off of your cable or satellite box.
Ok thanks. And one more question, i have my computer connected to the tv using a vga cable. However i can't listen to audio on the speakers. Could i buy a headphone jack to headphone jack cable and connect the two using that or will that not work?
Thanks!
Username: Jrbay
Post Number: 574
What you will need I think is a 3.5 mm headphone to RCA (red/white) similar to this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804 &p_id=665&seq=1&format=2
If you have extra inputs to the Samsung HTiB then run this cable to one of the aux inputs, if not run this to the TV.
Ok, Thanks
Username: Jrbay
Post Number: 575
Your welcome, enjoy!!!
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Connecting stereo system to tv with o... [ « Previous ] [ Next » ]
