Thread: HELP! Looking to buy home theater system! |
Silver Member Username: Mrskullz1
Brooklyn, New York
Post Number: 934 Registered: Feb-07
| Posted on Sunday, November 30, 2008 - 09:57 pm: |
Hey guys, I need to buy a nice home theater system. I have been to stores and listed to some but its not easy to know which will sound best when it comes to my house. My budget is about 350-400. i know it is not the highest but this is all i have to work with. I would really appreciate any advice i can get. I am also planning to buy a 52 inch LCD tv...any suggestions? i don't want to spend over 1400 for that...is it possible? Any suggestions? My room is about 12feet by 15feet (estimate). The tv will go in the center of the room and its a rectangular room. thanks |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 514 Registered: Feb-08
| Posted on Monday, December 01, 2008 - 07:54 am: |
It would help to know what you have listened to and some of the thoughts you had about it. You are absolutely correct in that it is extremely difficult to know exactly what it will sound like in your house but how critical are you going to be at a $400.00 price point? To give you a little more focus when shopping I would suggest that if what you hear in the store is pleasing enough the factors then become the look and feel meaning that the controls/remote make sense and are easy to use. One suggestion: Onkyo HT-S5100 7.1 Channel Home Entertainment System Regarding the TV you should be able to find several models from several manufacturers at your price point, that then would also boil down to look and feel issues. |
Brooklyn, New York
Post Number: 935 Registered: Feb-07
| Posted on Monday, December 01, 2008 - 09:41 pm: |
thanks...but that ht system is 600+ bux...where can you find that for cheaper if it is? |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2386 Registered: Feb-04
| Posted on Tuesday, December 02, 2008 - 12:47 pm: |
http://www.bestbuy.com/site/skuId=8796387&st=Insignia+NS-PDP50 |
Columbus,
Ohio
US
Post Number: 2387 Registered: Feb-04
| Posted on Tuesday, December 02, 2008 - 12:48 pm: |
http://www.bestbuy.com/site/olspage/skuId=8796387&st=Insignia+NS-PDP50 |
Columbus,
Ohio
US
Post Number: 2388 Registered: Feb-04
| Posted on Tuesday, December 02, 2008 - 01:22 pm: |
Sorry about the above posts....I was trying to get a URL to work properly. Anyway I think you are going to have a little trouble finding a 50+ LCD for that kind of money, except maybe for a refurb unit. You can get big bang for the buck with plasma. Best Buy is running a sale on their Insignia NS-PDP50HD-09 for $1199.99. Consumer Reports gave the Insignia NS-PDP50 (a 720 display) a "Best Buy", for what that's worth. Go to the Best Buy site and punch in the model number. As for the HTiB, I would look at the Sony HT-7200DH. It comes with a decent separate DVD player and features a real receiver -- you know, with inputs and outputs and stuff. http://www.bhphotovideo.com/c/product/550551-REG/Sony_HT_7200DH_HT_7200DH_Home_T heater_System.html And you can do a model search on the Sony site: http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=1055 1&storeId=10151&langId=-1&productId=8198552921665361563 |
Columbus,
Ohio
US
Post Number: 2389 Registered: Feb-04
| Posted on Tuesday, December 02, 2008 - 03:53 pm: |
Here's the rear panel of the Sony HT-7200 receiver:
Columbus,
Ohio
US
Post Number: 2391 Registered: Feb-04
| Posted on Tuesday, December 02, 2008 - 04:47 pm: |
Then again you could buy a real serious receiver like the Onkyo 605... http://www.bhphotovideo.com/c/product/543840-REG/Onkyo_TX_SR606S_TX_SR606S_Home_ Theater_Receiver.html Then you could save up for a real set of speakers like.... http://www.yambekaaudio.com/5speak.html OR http://www.fluance.com/fluan5speaks.html A lot of speakers for $300. Both these sets could use a subwoofer, but you can get along just fine until you can add one later. |
Brooklyn, New York
Post Number: 937 Registered: Feb-07
| Posted on Tuesday, December 02, 2008 - 08:09 pm: |
thanks John, i will look into your links posted above just after i write this msg. I am looking at this refurb unit from tiger(reputable) and would like to know if you would recommend taking a bite out of this unit. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=38054 73&CatId=3651 |
