Thread: Need Your Input On Speakers |
The Pig |
| Posted on Thursday, September 18, 2003 - 03:53 pm: |
Got a Yamaha rx-v1300 receiver. I need speakers and the wife will only go with something small. I can't go the front tower route, etc. I need some opinions on small speakers, 6.1 setup that will give me some good sound for both music and movies for somewhere between 0 and 1000 bucks. Thanks. |
qdog |
| Posted on Thursday, September 18, 2003 - 04:17 pm: |
check out these..I had a similar problem with my wife and bought these http://www.onhometheater.com/product/20020901.htm http://www.audiorevolution.com/equip/rbhcompacttheater/ |
Al C. Roach |
| Posted on Thursday, September 18, 2003 - 08:14 pm: |
I've seen reviews of the RBH CT-5's before, and they sound impressive, but where do you buy them? |
elitefan |
| Posted on Friday, September 19, 2003 - 04:36 pm: |
For Yamaha the only speaker I can recommend is Paradigm performance series like the Titan. Great sounding and not much money. |
Derek |
| Posted on Saturday, September 20, 2003 - 12:04 pm: |
Paradigm is VERY good. If you are looking for something smaller, goto http://www.energy-speakers.com/speakers/speakers.html and look at the Encore and Takes. Now Hear This http://www.nhthifi.com/home_product_vintage.asp?subjectid=12 Supers are small and finally the Point 5s from Athena http://www.athenaspeakers.com/ are small and easy to get. Best Buy even sells them. Athena and Energy are made by the same company. Hope this helps. |
