Thread: Need Some help |
New member Username: Donniebrasco
Post Number: 1 Registered: Nov-08
| Posted on Saturday, November 08, 2008 - 08:05 pm: |
ok.. Motorola Digital Cable box Sony STR-DG520 Multi Channel AV Xbox 360 Sharp Aquos Blue Ray Player I have everything I thought hooked up correctly.. Digital Bable box, I am running component cables and rca's from box to satellite in on the receiver.. Xbox 360 running component cables into the video input on the receiver. Blue ray running hdmi in to the bd in slot, and optical into the bd optical slot. running only HDMI into a panasonic 50inch plasme with 2 hdmi inputs.. I am getting no picture on anything, and only sound on the xbox 360.. So i am terribly confused.. Should i be running a component out into my tv for picture for the xbox and cable box? Sincerely, one who is lost.. |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 483 Registered: Feb-08
| Posted on Saturday, November 08, 2008 - 08:27 pm: |
According to this: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc &externalId=STRDG520qsgpdf&sliceId=pdfPage_1&docTypeID=DT_MANUAL_1_1&dialogID=33 117445&stateId=0%200%2033123255 yes you will need to run component to the TV. This is unfortunate but considering the cost of the AVR... |
Michigan
Post Number: 484 Registered: Feb-08
| Posted on Saturday, November 08, 2008 - 08:29 pm: |
BTW-You should be getting a picture from your Blu-ray, if you are not there must be a setting that is not done correctly. |
