Thread: Need some ht information |
Silver Member Username: Aaronjp1990
Lerwick,
Shetland
Uk
Post Number: 144 Registered: Apr-06
| Posted on Wednesday, October 15, 2008 - 02:16 pm: |
was wondering if this would be a good buy or could i get something better for the money? am looking at setup number 3 or 4 any input would be much appreciated. http://www.richersounds.com/information.php?cda=static&cst=plasmasystems |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 530 Registered: Jun-05
| Posted on Thursday, October 16, 2008 - 02:48 pm: |
Number 3 & 4 both look like decent buys. 4 is a good buy if you plan on going blu- ray, but if your not ready for blu-ray a mix and match of the 2 system could be in order. The Onkyo 606 is a nice piece and the Sony 40 LCD got a good write up. If you are not a big movie person( you own no DVD at all) you may or may not be a blu-ray person. |
Lerwick,
Shetland
Uk
Post Number: 145 Registered: Apr-06
| Posted on Thursday, October 16, 2008 - 05:21 pm: |
am planing to go blu-ray was thinking about getting a ps3 for that or would i be better with a separate dedicated blu-ray player? i am also thinking about hooking my computer up to my tv any idea if that would work any use? what would u recomend is a better amp the Denon AVR1909 or the Onkyo TXSR606? |
BREEZY POINT,
NY
Post Number: 532 Registered: Jun-05
| Posted on Friday, October 17, 2008 - 01:12 pm: |
I never hooked up a computer to a TV. Blu-ray stand alone vs PS3, If you have kids or are a gamer yourself PS3 has a lot going for it. If that is not the case there are many stand alone blu-ray players that are now cheaper than the PS3 , that was not the case a short time ago. The Onkyo 606 is the hot item today in receivers it is cheap $400-500 and comes with almost everthing you need, but the Denon is no slouch. |
Lerwick,
Shetland
Uk
Post Number: 146 Registered: Apr-06
| Posted on Friday, October 17, 2008 - 01:15 pm: |
ok thank you very much cleared up a lot of my questions. |
