Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > Denon or H/K
Author Thread: Denon or H/K
Justin D
I'm trying to decide between purchasing either the Denon AVR-985s or the Harman Kardon AVR 430. The receiver I choose will be powering Acoustic Research speakers. If it were you, which would you choose, and why? Thanks.
chadlb
I just did a 2 hour comparison yesterday between these two models and I chose the Denon as I prefereed the sound in 2 channel as with some songs the voices sounded muffled on the 430.
Username: Project6
Post Number: 1000
Have you listened to both?
For the Acoustic Research I'd go with the HK. Couple the Denon with the AC and I just didn't like the shrillness.
It is a matter of your preference so listen well.
cheers
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > Denon or H/K [ « Previous ] [ Next » ]
