Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Is it ok to place the center channel ...
Author Thread: Is it ok to place the center channel in the ceiling
Username: Sam_b
I have a 52" LCD mounted above the fireplace, and I am adding home theater system, so I was wondering if putting the center channel in the ceiling would affect the surround sound quality!
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 385
It will but if you get a speaker with an adjustable tweeter you can obtain resonable results.
Username: Dmitchell
Ottawa, Ontario
Post Number: 1527
The center should be as close to the as practical. There's a reason they put the center speaker(s) in movie theatres directly behind the screen.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Is it ok to place the center channel ... [ « Previous ] [ Next » ]
