Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > DVD audio not optimized
Author Thread: DVD audio not optimized
Username: Tonyginsf
I'm connecting up some new home theater hardware I've purchased. Most components seem to be working correctly; however, I have a DVD player (Sony DVP-NC685P) coming into a Sony receiver (STR-DE895) via coponent video and digital coax. No matter how the DVD is encoded, the only signal my receiver seems to want to use is PCM (48KHz). When I switch the source to my Comcast HD receiver, the display changes according to what the channel is putting out (Dolby v.1, Dolby v.2, etc.). However, the DVD will only cause the receiver to show the PCM I mentioned above. Am I missing something or not understanding something fully?
Thanx in advance for your input.
<<tony>>
Username: John_s
Columbus, Ohio
US
Post Number: 130
T.G.:
You must "enable" the DVD player's DD and DTS output by going into the on-screen audio setup menu on the player. You only have to do this once. The player will then output either DD or DTS depending on the particular DVD's setup choices for audio.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > DVD audio not optimized [ « Previous ] [ Next » ]
