Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > Digital output to digital output
Author Thread: Digital output to digital output
Username: Mjnoles1
Is their anyway to connect my audio system that only has a digital audio output to my dvd player which also has only a digital audio output and get it to work to give me a digital sound? If not is their any type of adapter or connector that could change a digital audio output to a digital audio input?
Thanks for the help
Username: Feot
Texas
Post Number: 26
no, no.
Username: Project6
Post Number: 641
there has to be an input there somewhere.
Mliberte
Is it possible to feed sound from a digital audio output (from, say, audigy) to analog input (RCA)?
Username: Project6
Post Number: 958
yes by using a digital to analog converter, check around, you'll find one eventually.
Frank2000
I connect my digital output of my DVD player to my home theatre receiver's digital input. But I get no signal. Why? Thanks.
Username: Project6
Post Number: 1041
you have to configure the dvd player to output digital sound and not analog/stereo.
go to the menu set-up and go to audio.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 19, 2004 > Digital output to digital output [ « Previous ] [ Next » ]
