Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Samsung HTX75 HTIB can I make it work...
Author Thread: Samsung HTX75 HTIB can I make it work with my Charter HD cable box???
Username: Massbrandon
So basically I have the above mentioned HTIB and a Samsung 40" LCD Tv. All I want to do is be able to use my HTIB when watching regular cable TV. I have CHarter HD Cable, all component wires, an Optical audio wire, and all speakers and wires. Thanks for any input you guys may have in advance.
Brandon
Username: Mccambley
BREEZY POINT, NY
Post Number: 516
Simply connect your cable box Video to the TV and the optical wire from cable box to the Samsung. You may have activate the digital out put on the cable box
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through January 04, 2009 > Samsung HTX75 HTIB can I make it work... [ « Previous ] [ Next » ]
