Thread: Okay To Drill Hole In Back Of Speaker? |
Bronze Member Username: Ronsweet2
Post Number: 12 Registered: Jul-08
| Posted on Sunday, August 17, 2008 - 03:05 pm: |
Hello: I am setting up my speaker system and have the surround speakers in place. Now I am attaching the left and right front speakers. I bought speaker brackets which I've mounted to the wall. In the directions, it says that to mount the speakers there must be a screw hole in the center of the speaker (on the back of the speaker). But there is no such hole on the two front speakers (there was one for the other two). Is it okay if I drill a hole in the center of the speaker to put on the bracket mount or would that mess the speaker up somehow? Thanks, Ron |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 368 Registered: Feb-08
| Posted on Sunday, August 17, 2008 - 04:03 pm: |
Hi Ron, If the speakers are light weight enough it might be better to glue a flange nut on the back rather than drilling a hole. I sent you a mail with more detail. |
Gold Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 1312 Registered: Feb-07
| Posted on Wednesday, August 20, 2008 - 11:37 am: |
Depends on the speaker. If it is an expensive speaker, obviously you do not want to be drilling holes in it. I've done this before for mounting speakers... just make sure you don't drill all the way through the wood - use very shallow screws. This would most likely compromise the sound of the speaker. |
