Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > Add a Cable Box?, Any Ideas?
Author Thread: Add a Cable Box?, Any Ideas?
Username: Kinstephen
Sacramento, CA
United States
Post Number: 8
Can someone give me an idea on how I should hookup a comcast cable box to my home theatre system? I'm getting one today and would really appreciate some help on this...
My original question and details of my home theater system is in this thread...
http://forum.ecoustics.com/bbs/messages/3/490788.html
Thanks,
Stephen
Sacramento, CA
United States
Post Number: 9
if it helps any, the comcast cable box has an RF IN, RF OUT, and a A/V jack (Red/White/Yellow).
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 340
Your cable box should have more on the back of it than that, doesn't it?
Username: Jrbay
Post Number: 341
Ideally you will be hooking another optical cable from the cable box to the DTV/CBL input of your Yamaha and another S-Video cable from your cable box to the DTV/CBL video section. If the cable box does not have these outputs (get a box that does) hook the composite (red/white/yellow) to the DTV/CBL inputs and run a yellow composite video cable to your TV.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > Add a Cable Box?, Any Ideas? [ « Previous ] [ Next » ]
