Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > Sony 5.1 surround sound help
Author Thread: Sony 5.1 surround sound help
Username: Dasoccerguy07
i have a sony dvd/home theatre system, all 5 speakers are hooked up properly. i only realized recently that sound was only comming out of the front lest and right speakers. i did a test on the setup menu and sound came out from all 5 speakers, but when i listen on tv, dvd, bluray and on the pc, sound still only comes out from the 2 front speakers, how can i fix this, any help would be appreciated
Username: Roks
Post Number: 10
check if the receiver has any settings for "stereo", "dolby digital" etc surround options. If it is set to "stereo", the sound will only come from the front L/R speakers even if you play a Dolby/DTS encoded dvd.
Try setting it to Dolby/DTS while playing dvds.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > Sony 5.1 surround sound help [ « Previous ] [ Next » ]
