Home > Message Board > Home Theater > Surround Sound > Ps3 Problem can only hear sound from ...
Author Thread: Ps3 Problem can only hear sound from tv [OR] home cinema not both?
Username: Chauhan7
hi i have a panasonic scht880 which has no hdmi or optical. On my ps3 my display is set to HDMI and my sound is selected as AV and the AV cables go to the reciever but i can only hear sound from the home cinema and no the tv but if i change the audio to hdmi i can hear the sound from the tv only.
I tried to use the hdmi audio and put the red and white in AUX on the system bu then i hear full sound from tv and only faint extrememly faint from the home cinema?? i've been looking everywhere but no one has a answer?
Username: Jrbay
Livonia [Detroit area], Michigan
Post Number: 327
Greetings Daven,
Are there audio outputs (red/white) from your TV? There is a chance that using those to your Panasonic could solve your problem.
Username: Chauhan7
then how would i connect to the surround sound?
Username: Jrbay
Post Number: 328
Connect the TV audio out to the Panasonic SCHT880 surround package.
Username: Chauhan7
ok so that would be a red-white to red-white?
and would it go into audio in on the system?
if you could get a image of the wire i need would be real help .
Thanks
Username: Jrbay
Post Number: 329
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803 &p_id=659&seq=1&format=1#largeimage
Username: Chauhan7
Thanks Jim i ordered one today from amazon (because monoproce dont ship to UK) hopefully it will work. Thanks again
Username: Chauhan7
The wire works 100% thanks so much !
Username: Jrbay
Post Number: 333
ENJOY!!!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Surround Sound > Ps3 Problem can only hear sound from ... [ « Previous ] [ Next » ]
