Thread: How to hook up sorround sound to sony tv without output outlet |
New member Username: Valmoran
Post Number: 1 Registered: Jun-08
| Posted on Friday, June 20, 2008 - 10:45 am: |
I would like to hook up my tv and dvd player to a sorround sound but when i try i don't get any sound from the speakers when i am playing only the television. Can you help me with the connections or wiring |
Silver Member Username: Jrbay
Livonia [Detroit area],
Michigan
Post Number: 298 Registered: Feb-08
| Posted on Friday, June 20, 2008 - 12:01 pm: |
Do you have a cable/satellite box? |
Post Number: 2 Registered: Jun-08
| Posted on Friday, June 20, 2008 - 04:05 pm: |
no i do not have a cable box. |
Michigan
Post Number: 301 Registered: Feb-08
| Posted on Friday, June 20, 2008 - 04:49 pm: |
So I assume you are taking audio directly out of your DVD player? How are you trying to get audio out of your TV? If it is from a digital source that might be the cause of this problem. Try taking an analog (red/white RCA) out to your receiver. |
Post Number: 3 Registered: Jun-08
| Posted on Saturday, June 21, 2008 - 03:44 pm: |
I just have a dvd player, a sanyo tv without audio out. Could tou give me an idea so can get the tv sound from the sorround sound |
Michigan
Post Number: 303 Registered: Feb-08
| Posted on Saturday, June 21, 2008 - 04:11 pm: |
You will need to get a cable box if your TV does not have audio outputs. |
Post Number: 4 Registered: Jun-08
| Posted on Sunday, June 22, 2008 - 12:57 am: |
Is it possible hook up a vcr to the tv and reciever to get the audio from the tv through the tv. |
Michigan
Post Number: 308 Registered: Feb-08
| Posted on Sunday, June 22, 2008 - 08:30 am: |
To answer your previous question: If you have a VCR you could run the cable into it, use it's tuner for watching TV and it's audio output to your Receiver for listening to surround. To answer your latest question: If you want sound out of your VCR to your receiver and TV there are two ways to go. The best way is to get TWO RCA Y splitters: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803 &p_id=663&seq=1&format=2 and run red/white RCA cables to both your VCR and receiver. The second way is to simply run RF out (coax cable ) out of your VCR to your TV and a red/white RCA cable to your receiver. Hope this helps |
