Thread: Velodyne DD-18...how would you match it? |
New member Username: Sadquark
Post Number: 2 Registered: Jun-08
| Posted on Thursday, June 05, 2008 - 03:15 am: |
I used to have a pure music setup with a Denon 3805 pushing a Velodyne DD18 and 6 matched Mordaunt Short 908 Bookshelfs. This was an incredible music set up, but I have since moved to a larger house and would like to change things up to a home theater using some of the same components. Four of the MS908's have been consigned to my parents system leaving me with 2 908s and the DD18. My question is...If you had about 1500 right now, what would you do? Should I keep the 908's as my Left and Right Channel, buy a MS 901 Center, and the MS 506 Bipole rears? or... Get a whole new set of speakers to match the DD-18? If so, what? Incedentally, I am looking at aperion audio's Intimus line as their rear surrounds offer that nifty bipole/dipole switch and that sweet piano black finish matches the DD 18 perfectly (not really a concern) Anyway, your input would be HUGELY welcome! |
Post Number: 4 Registered: Jun-08
| Posted on Thursday, June 05, 2008 - 03:24 am: |
Mordaunt-Short 912's, not 908's |
