Home > Message Board > Home Theater > Bragging Area > This is what im aiming for
Author Thread: This is what im aiming for
Username: Javier420
Desert Hot Springs, United States
California
im aiming for 100 bucks stereo from walmart...has 2 tweaters with subwoofers...and aiming for a new tv.. i was wonder if i ever get it how would i connect it to the tv?
Relevant Product Info
Username: Jrbay
Livonia Detroit area, Michigan
Post Number: 133
Depends on the stereo, we need some more details but I would suspect that you will not be thrilled with a $100.00 stereo.
If you want to use a system for a TV look into a 5.1 Home Theater In A Box.
Username: Boulderdashcci
Canton, Mass
Post Number: 21
If you can wait, I'd save up and go for something like http://shoponkyo.com/detail.cfm?productid=HT-SR600&modelid=140&group_id=1&detail =1&ext_war=1 which is $169 if you register with their site. It will give you a lot more options if you ever want to expand later. If you can wait even longer, jump up to http://shoponkyo.com/detail.cfm?productid=TX-SR505&modelid=62&group_id=1&detail= 1&ext_war=1 and find a decent set of used bookshelf speakers (Paradigm Atoms come to mind, craigslist is your friend) which will be a huge jump in quality. Then, add pieces as you go. Either way though, generally a $100 Walmart system will leave a lot to be desired.
Username: Huron
Post Number: 422
freddies right, waiting saving and good research is the key, wallmart crappp is just that, crappppp
Username: Dmitchell
Ottawa, Ontario
Post Number: 903
Freddie and Angelo are right. You'll be throwing your $100 bucks down the toilet.
Get at least an entry level Yamaha/Pioneer/Denon receiver (they're cheap) and maybe some Fluance speakers.
Username: Levelzero
Post Number: 27
Wow Freddie! That was a darn good find! Great post!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Bragging Area > This is what im aiming for [ « Previous ] [ Next » ]
