Thread: Getting grills on in ceiling speakers |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 481 Registered: Jun-05
| Posted on Thursday, April 17, 2008 - 01:48 pm: |
Does anyone have a trick for getting very tight grills on in ceiling speakers? I was going to cut a small V on the grill where it is bulging out and preventing the gril to go in. |
Relevant Product Info
Silver Member Username: Jrbay
Livonia Detroit area,
Michigan
Post Number: 130 Registered: Feb-08
| Posted on Thursday, April 17, 2008 - 05:07 pm: |
That's been known to work (cutting a v in about three or four places and bending accordingly but if the grill will go on and stay it doesn't really need to be flush. |
BREEZY POINT,
NY
Post Number: 483 Registered: Jun-05
| Posted on Sunday, April 20, 2008 - 10:42 pm: |
Thanks for the advice Jim, I was concerned if cutting a V might twist the metal up in such a way that I never could get them on. Anyone else have any experience with tight grills. |
Silver Member Username: Huron
Post Number: 420 Registered: Mar-07
| Posted on Tuesday, April 22, 2008 - 03:36 am: |
yes, I think a firm but jentle spanking is in order for those tight, grills? yes were talking about grills, OK let me think,,,,,,,,,,what about a thin peace of bent metal and use it like a shoe horn, or lube it, come on casey get inventive hear, maybe a small dremel tool and slowly work it untill it snaps in to the tightness you want, ohh yes |
BREEZY POINT,
NY
Post Number: 486 Registered: Jun-05
| Posted on Thursday, April 24, 2008 - 10:06 pm: |
Tried "a firm but jentle spanking is in order for those tight, grills", but that did not work. Cut one small V half way down the side wall, where I had marked with a pencil at the point of a bulge. The grills went on with out much struggle. |
Post Number: 423 Registered: Mar-07
| Posted on Friday, April 25, 2008 - 02:06 am: |
did someone enjoy the spanking? did you use a dremel for the cut? I want some kind of credit hear!!! |
Michigan
Post Number: 150 Registered: Feb-08
| Posted on Friday, April 25, 2008 - 06:46 am: |
You definitely get credit Angelo for turning this into an interesting project!!! |
Post Number: 424 Registered: Mar-07
| Posted on Friday, April 25, 2008 - 02:09 pm: |
thanks jim that means a lot to me, Im going threw a ruff time and need some chearing up, like how about if I got a spanking, preferably by a a slew of amazonian girlls, to bad caseys holding back on details |
Michigan
Post Number: 155 Registered: Feb-08
| Posted on Friday, April 25, 2008 - 03:04 pm: |
Indeed!!! Details are VERY important to this forum!!! |
