Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Speaker wire gauge
Author Thread: Speaker wire gauge
Username: Jdsaenz1
Post Number: 31
I'm looking to buy a large amount of speaker wire, but am not sure as to what gauge I should look for.
Is 'out-of-the-box' speaker wire around 20 gauge? If so, this means, for better quality sound, I should look for 18 or 16 (maybe larger) gauge wire?
Thanks for your help.
Username: Project6
Post Number: 611
try 12-14 gauge.
cheers
Username: Sandiego
out of the box might be 20 guage at the largest. Someone on here said they called Onkyo about the wire that came with their HT-S770 HTIB and the rep told him it was 24 guage. I agree with Berny, you will want larger wires for optimal sound. the more power you are running the larger the guage you should need. I use 16 guage with my system and it sounds great. you coudn't go wrong with the 12 or 14. Good Luck
Home > Message Board > Home Theater > Home Theater Speaker Packages > Archive through October 26, 2004 > Speaker wire gauge [ « Previous ] [ Next » ]
