Thread: PS3 and Hitachi 51SWX20B |
Silver Member Username: Pablo
Post Number: 103 Registered: Mar-06
| Posted on Sunday, March 30, 2008 - 11:23 pm: |
I have Hitachi 51SWX20B and just bought PS3. Hitachi has HDCP V1.0 DVI. When I used HDMI cable with DVI adapter - no picture. I did the same set up with my dell monitor and it is working fine. So this is not PS3 or cable. What is wrong please?? Pablo |
Silver Member Username: Jrbay
Livonia Detroit area,
Michigan
Post Number: 103 Registered: Feb-08
| Posted on Monday, March 31, 2008 - 05:18 am: |
Found so far: 2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer. 3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed on the screen in its digital form. This is directly from the TV manual and it would appear as though your PS3 behaves like "a DVD player from a personal computer" and you have some sort of copy protection problem going on. So that defines the problem, more research is required for the solution. |
Post Number: 105 Registered: Mar-06
| Posted on Monday, March 31, 2008 - 05:24 am: |
I saw this but PS3 and Hitachi are HDCP so I thought it will work. I think I have to buy component cable. dam. Pablo |
Michigan
Post Number: 104 Registered: Feb-08
| Posted on Monday, March 31, 2008 - 05:45 am: |
From Sony: The HDMI cable is not included with the PLAYSTATION 3. If your display does not support HDMI input, you may attempt to use an adaptor (i.e., HDMI to DVI converter), however, we do not have any recommendations and cannot guarantee compatibility with the PLAYSTATION 3. Visit our Knowledge Base article for proper HDMI installation guidelines. We do not have any recommendations for converters that will change the output connector type from an HDMI cable to another type of video connection (i.e., HDMI to DVI converters). We also cannot guarantee that these converters will work with the PLAYSTATION 3 system.Additionally, the PLAYSTATION 3 system is only able to use one video output port at a time. We do not have information regarding connecting the PLAYSTATION 3 system to multiple displays. The bottom line then would be to try an HDMI to Component cable. |
Michigan
Post Number: 105 Registered: Feb-08
| Posted on Monday, March 31, 2008 - 05:47 am: |
Sorry, I didn't see your post until I sent mine but it appears as though we both reached the same conclusion. I have seen that the component cable is cheaper that the DVI so there is at least that one the bright side! |
New member Username: Levelzero
Post Number: 6 Registered: Aug-07
| Posted on Monday, March 31, 2008 - 03:38 pm: |
In case you didn't know, you can use SONY's component set up with either the PS2 or PS3. No need to purchase the aftermarket brands like Mad Catz, or the other one, SONY's brand is nice and priced resonable. Try Gamestop, Newegg.com, etc. to compare prices. |
Post Number: 106 Registered: Mar-06
| Posted on Monday, March 31, 2008 - 06:43 pm: |
I think component will be the only way to go. But sony component (http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000F S10084529&catid=) it is a bundle with audio. I send audio to arcam receiver via optical, so I will buy 3 party component for PS3. thanks for the help Pablo |
Post Number: 107 Registered: Mar-06
| Posted on Tuesday, April 01, 2008 - 08:13 am: |
I got sony cable - was told that picture quality would be much better then 3rd party. And will use optical to Arcam for Audio. Still dissapointed about this DVI. I was told that the problem is my tv's DVI is 1.0 and ps3 hdmi is 1.3. That is why they are not compatible. Pablo |
Michigan
Post Number: 106 Registered: Feb-08
| Posted on Tuesday, April 01, 2008 - 08:55 am: |
Compatibility issues in THIS industry??? No way!!! I am glad you are up and running though! |
Post Number: 108 Registered: Mar-06
| Posted on Tuesday, April 01, 2008 - 09:59 am: |
just called hitachi and was told that it is lotery. some devices will work some will not, and there is nothing they or I can do. Pablo |
Post Number: 118 Registered: Mar-06
| Posted on Monday, May 12, 2008 - 07:33 am: |
GOT IT!!! DVI-D is the answer! Just read this at some forum went to the futureshop and bought single link dvi-d on one side, hdmi on the other and PS3 connected with my hitachi no problem at 1080i. It was frustrating but finaly I found solution. Pablo |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2261 Registered: Feb-04
| Posted on Monday, May 12, 2008 - 09:13 am: |
"I got sony cable - was told that picture quality would be much better then 3rd party." "I was told that the problem is my tv's DVI is 1.0 and ps3 hdmi is 1.3. That is why they are not compatible." "just called hitachi and was told that it is lotery. some devices will work some will not, and there is nothing they or I can do." With this kind of "help" available from the "experts," no wonder people are confused. Pablo, when I read your original post, I knew something was wrong because my 15 foot HDMI cable with HDMI/DVI adaptor works fine on my old Hitachi. |
