Home > Message Board > Home Theater > Home Theater in a Box > Bose 321 Series II Issue
Author Thread: Bose 321 Series II Issue
Username: Knightmare
When I play DVDs through my Bose 321 Series II, there is a blue tint that shows on the screen while the DVD is playing. Any clue on what the problem is and how it can be corrected?
Thanks!
Relevant Product Info
Username: Jrbay
Livonia Detroit area, Michigan
Post Number: 94
How are you connecting the Bose unit to your TV? If the whole screen is Blue and you are using component cables (RCA type Red, blue, and green) then check to make sure they are in the proper position.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater in a Box > Bose 321 Series II Issue [ « Previous ] [ Next » ]
