Home > Message Board > Home Theater > Home Theater Setup & Planning > Interesting Monopole vs. Dipole Quest...
Author Thread: Interesting Monopole vs. Dipole Questions -- Help
Username: Grossn
Hi, I bought Speakercraft in wall dipole speakers and found out they were too wide to fit where I need them to fit in the wall...so I don't think I can install them properly and would like some advice. Is it OK to install the dipoles horizontally/sideways near the ceiling? Or would it be better to just use monopole speakers on either side of the listening area and place them higher up for additional diffuse-action for movies? Or what about using two monopoles on top of each other but positioning the baffles towards opposite ways (17 degrees each for total of 34 degree offset of the sound direction)? Can anyone offer some really solid advice?? Thanks a lot!
Relevant Product Info
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater Setup & Planning > Interesting Monopole vs. Dipole Quest... [ « Previous ] [ Next » ]
