Home > Message Board > Home Theater > Home Theater in a Box > PLEASE HELP IM DESPERATE :-( philips 37...
Author Thread: PLEASE HELP IM DESPERATE :-( philips 3750w
Username: Stu123
ive got a philips 3750w dvd/amp ive selected the last option as you go along the menu at the top it said p-scan or something and ive lost the picture signal from the player.I was using a european scart lead.
Relevant Product Info
Username: Jrbay
Livonia Detroit area, Michigan
Post Number: 82
Can you give us a model number? That would be helpful. This may not be exactly the procedure for your particular model but it may get you started:
http://www.p4c.philips.com/files/h/hts3151d_37/hts3151d_37_dfu_aen.pdf#search='no%20picture'
Username: Stu123
yes its the LX3750W/25S
Username: Stu123
have you any idea what could of caused this,im thinking ive switched it to component or something but the dvdplayer dosent even have component at the back
Username: Stu123
http://www.amazon.com/gp/product/B00008XL1O/ref=cm_cr_pr_product_top
Username: Stu123
i think ive got to turn off progressive scan,strange though as my is 1080p
Username: Jrbay
Post Number: 84
On
To enjoy the full quality potential offered by progressive
scan feature, a progressive scan TV is required.
● Press 4 to activate the Progressive Scan.
– Progressive Scan icon will light up.
– If the TV System is set to PAL, the TV System will
automatically set to NTSC.
Off
Select this if a normal covertional TV is connected to
your DVD system.
● Press 4 again to restore to normal TV system.
– Interlace Scan will appear.
Username: Stu123
tried it and still no picture
Username: John_s
Columbus, Ohio
US
Post Number: 2181
"i think ive got to turn off progressive scan,strange though as my is 1080p"
Progressive scan is not available on Scart leads. Use component cables instead.
Username: Stu123
Post Number: 7
the player hasnt got component
Username: Stu123
Post Number: 8
£4 by paypal for anyone who sorts this out for me
Username: John_s
Columbus, Ohio
US
Post Number: 2184
"the player hasnt got component"
Really? You've got a DVD player with a "p-scan" option and there's no component? Difficult to believe. Look for YPbPr (red-green-blue) outputs.
The only other way to get prog scan out of a player is HDMI. Do you have that?
Username: Stu123
Post Number: 9
definately no component and hdmi as its about 4 years old,i havent a clue ehat i selected then but as soon as i selected it the picture went and the sound and speakers as still working as normal
Username: John_s
Columbus, Ohio
US
Post Number: 2185
Strange. I just read your owner's manual and nowhere is there a mention of progressive scan. Actually, that makes sense since there is no component or HDMI outputs. So the problem must lie elsewhere.
So the next question is did you switch the video output in the set up menu to "S-VIDEO"?
I suppose that's going to be a little difficult to check since you most likely can't see the menu now, correct? If so, hook up an RCA phono jack from the yellow video out on the amp to the composite in on the TV. The menu should show up then, and you can switch the video back to "SCART".
Here's hoping this easy fix is your problem....Upload
Username: Stu123
Post Number: 10
yes ive used the yellow video connector and getting the same as with scart,its saying no signal on my 1080p lcd and on my ordinary crt about 6 years old im just getting white horizontal lines zooming across on a black background.Its driving me crazy i dont know what ive selected for it to do this
Username: Stu123
Post Number: 11
its definately got p-scan as its saying that on the front display when i put a dvd in and play it,i think the american version has component but mine hasnt as its the europrean one,i'll increase the reward lol £5 by paypal.Ive selected the last option across the top theres about 13 options as you go across if anyone has a sinilar player they could tell me what ive pressed.
Username: Stu123
Post Number: 12
the user manual that jim bay gave is wrong here is the correct one
http://www.p4c.philips.com/files/l/lx3750w_25s/lx3750w_25s_dfu_eng.pdf
Username: Stu123
Post Number: 13
YES WHOOHOO!!!!!! I DID IT I HAD TO PRESS STOP FOR 10 SECS BUT ON THE MACHINE NOT THE REMOTE now i can sell my other dvd player and make £50 :-)
Username: John_s
Columbus, Ohio
US
Post Number: 2186
Good news Stuart! How did you know to do that? User manual? If so, what page?
Username: Stu123
Post Number: 14
Well id seen a few other stories of people losing the picture on philis machines although it wasnt my model i was thinking i could of sone the same thing.It didnt tell you what to do in the european manual but i found the american manual on amazon and its in there page 21 http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000022805.pdf
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater in a Box > PLEASE HELP IM DESPERATE :-( philips 37... [ « Previous ] [ Next » ]
