Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > New TV (pdp5080), old receiver (JVC R...
Author Thread: New TV (pdp5080), old receiver (JVC RX-884), no 5.1!
Username: Cornfused_in_illinois
Rockford, Il
Really struggling to get Dolby 5.1 with my new combination. I have the newest Motorola/comcast box with an HDMI cable going directly to my Pioneer PDP5080, and an optical cable from the TV to the optical input on my JVC RX-884 receiver. Cannot find a combination to get dolby 5.1 to save my life. Any suggestions?
Username: Project6
Post Number: 15396
Have you confirmed that the broadcast from your cable company is in 5.1?
Having a digital connection is no guarantee that you will be getting 5.1 out of your TV channels.
Do you get 5.1 when watching DVDs?
Username: John_s
Columbus, Ohio
US
Post Number: 2176
Greg, your Pioneer will not output any signal on its optical output from any incoming HDMI signal.
Connect the cable box's digital output directly to the JVC.
Username: Mccambley
BREEZY POINT, NY
Post Number: 479
John S is correct the digital out on the TV is used only if you have a roof antena hooked up to the TV as your source. If you are using a cable box use the digital out on the cable box to the receiver.
Username: Floyd_1977
Montgomery, IL
Post Number: 118
Yes, the optical out from the TV is likely for sending digital audio to your receiver when your TV is tuned to OTA broadcasts.
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through July 23, 2008 > New TV (pdp5080), old receiver (JVC R... [ « Previous ] [ Next » ]
