Thread: Centre Channel Speaker |
New member Username: Best_scents
Brampton,
Ontario
Post Number: 1 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 10:28 am: |
We recently (by ourselves) installed a Yamaha 5.1 home theatre system. It sounds pretty good but I would like it to sound the best it should be and my question is...should most of the sound be coming from the centre channel speaker. Also, should ALL the speakers be facing square, e.g. the two small speakers are behind the centre speaker facing in a little and also the two mini tower speakers are facing a little in toward each other. The system is not exactly in the middle of the sofa where we sit and listen to it but the centre speaker IS the loudest. We hear very little sound from the 2 back tower speakers at any time. We're not experienced at this kind of system but I AM a little annoyed at "it's good enough"... Thanks for any advice received. |
Brampton,
Ontario
Post Number: 2 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 01:05 pm: |
I forgot to mention that the system is A Yamaha HTR-6030, Speaker NS-AP2800 & Subwoofer system YST-SW011. Thanks again |
Platinum Member Username: Project6
Post Number: 15076 Registered: Dec-03
| Posted on Saturday, February 16, 2008 - 01:39 pm: |
Here is a nice little guide and other tips you can use for setting up: http://www.audioholics.com/tweaks/speaker-setup-guidelines/ |
Brampton,
Ontario
Post Number: 3 Registered: Feb-08
| Posted on Saturday, February 16, 2008 - 04:00 pm: |
Thanks Berny, I will have a look. |
