Thread: Polk audio |
New member Username: Tbaggins
Vancouver,
Wa
Us
Post Number: 1 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 09:18 am: |
Hi, I am assembling a modest theater setup and am hoping for some helpful insights (or clever insults) So far I have: onkyo ds575x reciever polk rti6 bookshelf speakers and csi3 center- my sub and rears are going to be replaced-- probably with matching polk gear because its a good price range for me. I'd like to know if there is an equalizer that works with integrated amplifiers. Also, I'd like a cd player that rips mp3s without a computer. Any all guidance appreciated. |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 15014 Registered: Dec-03
| Posted on Wednesday, February 13, 2008 - 10:00 am: |
An equalizer?...You must be a hardcore car audio guy |
Post Number: 15015 Registered: Dec-03
| Posted on Wednesday, February 13, 2008 - 10:02 am: |
You have a pretty decent system. What are it's weaknesses that you feel a need for an equalizer? What do you seek to improve? |
Vancouver,
Wa
Us
Post Number: 2 Registered: Feb-08
| Posted on Wednesday, February 13, 2008 - 10:25 am: |
Well, I find that the amplifier presets work pretty well for pop music and movies but tend to bully jazz and classical tracks. I'm not too familiar with the technical terms but I guess I'd say the highs and lows are overstated. Particularly orchestral music. I can get by adjusting bass and treble but I think an equalizer might be better. Also, my cd player is really old. It makes a clicking noise after a while and really must be replaced. I was hoping for suggestions on one that played mp3's. |
Silver Member Username: Hannjeff
Halifax,
Nova Scotia
Post Number: 229 Registered: Jun-06
| Posted on Tuesday, May 06, 2008 - 08:50 am: |
You should be able to override the presets and set in the highs, mids and lows your self. Aside from that I can see a eq being more trouble than it is worth. You would have to run it through your pre/post channel, and then (somebody correct me here) you would completely bypass the pre-amp in the receiver, and you would then need a separate unit? |
