Home > Message Board > Home Theater > Home Theater Setup & Planning > HDMI to DVI Adapters?
Author Thread: HDMI to DVI Adapters?
Username: Mikko123
First post everyone:-)
I'm hooking up my new home theater system and would like to use the 50" plasma I bought a couple years ago since I have no money left after buying all the new audio components. However it only has a DVI input and my receiver is of course HDMI 1.3. I know that there are HDMI to DVI adapters available inexpensively and I wanted to get opinions or feedback about any quality loss that I might expect compared to DVI. Eventually I'll replace the TV, but if the difference is minor I won't feel the need to rush out and switch.
Thanks!
Relevant Product Info
Username: John_s
Columbus, Ohio
US
Post Number: 2101
Michael, my HDMI®DVI adaptor works great on my 4 year old Hitachi 50". I just now started to use my TV's DVI input with a Toshiba HD DVD. Ordered the adaptor and a 15 ft. HDMI cable from monoprice. Couldn't be happier. There is complete backwards compatibility betweeen HDMI and DVI, so there's no reason to expect any video compromise when feeding HDMI into a DVI input.
"I know that there are HDMI to DVI adapters available inexpensively"
Check this out.
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041902 &p_id=2029&seq=1&format=2
My cheap cable works great too.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024009 &p_id=2529&seq=1&format=2
Username: Mikko123
Thanks so much John!
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Home Theater > Home Theater Setup & Planning > HDMI to DVI Adapters? [ « Previous ] [ Next » ]
