Home > Message Board > Home Theater > Home Theater Speaker Packages > Home threatre Package
Author Thread: Home threatre Package
Username: Subrtpal
I want to purchase anyone of the following combination:
a) Onkyo-605 a/v receiver with Tanoy Mercury F2 bookself & FC speakers
b) Onkyo-605 a/v receiver with B&W 600S3 bookself & matching centre
c) Yamaha RXV459 a/v receiver with Paradigm mini monitor bookself & CC190
d) Denon AVR1507 a/v receiver with Polcardio bookself and matching center
Latter i will upgrade to 5.1 system
Pl. suggest me which one will be the best combination. My priority is audio than Video.
Thanks & Regards
Subrata Pal
Username: Mccambley
BREEZY POINT, NY
Post Number: 475
What about the Denon 1507 with the Paradigms and upgrade the center to the CC290
Username: Project6
Post Number: 14676
I would go for the Denon myself.
The question is...have you listened to any of these equipment at all?
What we like may not be what you prefer.
Username: Subrtpal
Pl.suggest which one will be the best combination:
a) Denon AVR1507 with Tanoy Mercury F2 bookself & FC speakers
b) Denon AVR1507 with B&W 600S3 bookself & matching centre
c) Denon AVR1507 Paradigm mini monitor bookself & CC190
Thanks
Username: Project6
Post Number: 14777
They are all great combinations. Pick one and run with it.
Username: Subrtpal
I have Denon AVR 1707. Which bookself speaker will be good combination: KEFiQ1 or Tannoy mercury F2??
Thanks & Regards
Username: Project6
Post Number: 15390
Listen to both and then pick one that you like.
Username: Subrtpal
I have Denon AVR 1707. I want to procure KEFiQ5 speakers. Is it a good combination and whether Denon 1707 is sufficient for KEFiQ5 ??
Thanks & Regards
Username: Jrbay
Livonia Detroit area, Michigan
Post Number: 92
Greetings,
The usual recommendation is to listen to any combination you may want to put together because you are the only one to say whether it sounds good or not. Technically the Denon may be a bit underpowered for the KEF's but the specs say the 75 watts ought to work (power handling 15-130 watts). If you can't listen to them before buying them then you are taking a bit of a risk but I am sure you could do a LOT worse!
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Speaker Packages > Home threatre Package [ « Previous ] [ Next » ]
