Home > Message Board > Home Theater > Home Theater Speaker Packages > Using Bose SoundDock speakers with la...
Author Thread: Using Bose SoundDock speakers with laptop computer
Username: Nette
Does anyone know of a cable that will plug into the audio output from a laptop into the iPod dock of a Bose SoundDock speaker system? It does not have any other input. The cable would need one end like a regular headphone that plugs into a laptop and the other end would need to be like the input end of an iPod where you connect it to the computer to sync or charge the iPod.
Neither the Apple Store nor Bose has such a thing.
Thanks for any suggestions
Username: Project6
Post Number: 14582
I don't think they have that adapter out just yet. You are going to have to rig one yourself.
Username: Nette
Thanks, Berny. How would I go about rigging one myself? Is it complicated, like hooking wires together? Or do you think there are there parts I could buy and plug together?
Jean
Username: Project6
Post Number: 14631
I wouldn't do it unless you are willing to open up your Bose Soundock.
It is better to just buy an external set of speakers...they are cheap nowadays.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Speaker Packages > Using Bose SoundDock speakers with la... [ « Previous ] [ Next » ]
