Thread: Help: Only 2 ch. input on Yamaha RX-V461 when using digital 5.1 DVD inputs |
New member Username: Gorovers
Signal Hill,
CA
United States
Post Number: 1 Registered: Jan-08
| Posted on Monday, January 21, 2008 - 03:00 pm: |
I need help setting up my new Yamaha RX-V461 receiver. I've tried 2 different DVD players (both with 5.1 capability and coax digital audio outputs) as "DVD input" sources for the receiver. The Yamaha front-panel input icons consistently show only 2-channel (FL/FR) instead of 5.1 input icons. Sound comes through via DVD so (new, orange) coax digital audio cable is fine. I've tried full power shut-down on the receiver, plus factory setting reset. Yamaha tech support isn't replying to my "help" email. Any advice?? |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 14417 Registered: Dec-03
| Posted on Monday, January 21, 2008 - 03:43 pm: |
Have you read the manual for your DVD player? |
Silver Member Username: Mccambley
BREEZY POINT,
NY
Post Number: 474 Registered: Jun-05
| Posted on Tuesday, January 22, 2008 - 07:28 pm: |
These devices are not plug and play. Every DVD player needs to be set up to allow the Digital Bit stream to be actibvated. Like Berny said read. |
Gold Member Username: Samijubal
Post Number: 3726 Registered: Jul-04
| Posted on Wednesday, January 23, 2008 - 11:19 pm: |
Go into the player audio menus and set the digital audio output to bitstream. |
Signal Hill,
CA
United States
Post Number: 2 Registered: Jan-08
| Posted on Thursday, January 24, 2008 - 01:11 am: |
Thanks guys. Thought I read the manual fully, but missed the bitstream part. Everything works terrific now! Thanks again... |
