Home > Message Board > Home Theater > Home Theater Speaker Packages > Sony ht-k25 'unlock' message
Author Thread: Sony ht-k25 'unlock' message
Username: Scottjords
Could someone please help.
I have been using my sony ht-k25 home theater unit for some time without any problems.But now I get the message 'unlock'when trying to use on the dvd setting.It works fine on the tv and satellite settings.
Any ideas?
Username: Jrbay
Livonia Detroit area, Michigan
Sony has made up it's mind which input you should be using and locks out the others. from Sony:
The word UNLOCK may appear in the display if there is a problem receiving a digital audio signal. Follow the steps below to troubleshoot this issue.
1. Ensure the correct input is selected to receive the Audio/Video (A/V) from the appropriate source.
2. Ensure a digital cable is connected to appropriate DIGITAL jack.
3. Ensure the other end of the digital cable is properly connected to the A/V source.
4. Ensure the A/V source is set appropriately to output a digital signal.
NOTE: The A/V source may have a DTS setting that needs to be turned on, or a DPCM setting that needs to be set to Dolby Digital.
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Theater > Home Theater Speaker Packages > Sony ht-k25 'unlock' message [ « Previous ] [ Next » ]
