Thread: Surround Sound With 4 Speakers? |
Bronze Member Username: Billru44
Post Number: 16 Registered: Jan-05
| Posted on Monday, December 31, 2007 - 11:01 am: |
Hey. I'm in the process of building a surround sound system. Currently, I have 2 Front speakers, and 2 Rear Speakers are on the way. Will i get anything out of this (will most receivers be able to recognize only 4 speakers)? I have a JVC RX8040B receiver. |
Relevant Product Info
Bronze Member Username: Mr_audio
St. Louis,
MO
Post Number: 16 Registered: Dec-07
| Posted on Monday, December 31, 2007 - 06:49 pm: |
Sure. You should be able to tell the receiver that you have no center channel and it will split the center channel signal between the two fronts. I ran my stuff like that for a long time before I finally got a center speaker. |
Silver Member Username: Dmitchell
Ottawa,
Ontario
Post Number: 487 Registered: Feb-07
| Posted on Tuesday, January 01, 2008 - 11:36 am: |
Yup. Most A/V receivers have a center channel setting called "Phantom" mode. Set it to that and the dialog will be split between the two fronts. |
Gold Member Username: John_s
Columbus,
Ohio
US
Post Number: 2010 Registered: Feb-04
| Posted on Tuesday, January 01, 2008 - 11:59 am: |
On Bill's JVC, there is a specific setting. Under "Quick Speaker Setup" all needs to be done is to dial in via the receiver's multi jog 4.0 CH. This yields Main: Large Center: None Surround: Small Surr. Back: None Subwfer: No Obviously, Bill would have to change this setting if he adds more speakers. |
