Thread: Audio Problem |
New member Username: Krisncrash
Austrakia
Post Number: 1 Registered: Dec-07
| Posted on Sunday, December 30, 2007 - 04:09 am: |
I have a Lenoxx AVR 100 5.1 Ch AV Receiver, The prob i am having is when i am playing DVD's and there is silence on the audio like between lines in a song or between lines in a movie, the sound from the receiver goes off as if it is muted then kicks back in after a few seconds. This problem only occurs when palying DVD's or audio CD's. When watching TV there is no sound probs at all. Very frustrated and any help would be appreciated. |
Relevant Product Info
Platinum Member Username: Project6
Post Number: 14293 Registered: Dec-03
| Posted on Saturday, January 12, 2008 - 05:52 pm: |
What DVD player are you using? |
Austrakia
Post Number: 2 Registered: Dec-07
| Posted on Sunday, January 13, 2008 - 06:58 pm: |
DVD Player is JMK 5.1 Channel |
New member Username: Cavanagh_1
Post Number: 1 Registered: Jan-08
| Posted on Sunday, January 20, 2008 - 02:11 pm: |
The system is not working audo cal gives error 20 message then push enter, no success. Can some one suggest what to do next? Katherine |
Post Number: 14400 Registered: Dec-03
| Posted on Monday, January 21, 2008 - 12:57 pm: |
Brendan, is that a portable DVD player? What is "audo cal"? |
Austrakia
Post Number: 3 Registered: Dec-07
| Posted on Tuesday, January 22, 2008 - 03:53 am: |
Hi Benny,no it is not a portable. I am still having the same problem and now also with TV as well, i am at my wits end...........Help plssssssssssss. |
Post Number: 14425 Registered: Dec-03
| Posted on Tuesday, January 22, 2008 - 09:50 am: |
If the audio is cutting out on both TV broadcasts and DVD sources, then your receiver is at fault. It may need to be repaired or replaced. You can narrow it down to the culprit. On your DVDs, check if the audio cuts out in the same time frame all the time. If it does then it is the DVD source itself, but if it is intermittent, then it is the receiver. For TV broadcasts it is usually in cycles and usually happens in a pattern if it is a broadcast issue. If it is intermittent...then it is your receiver. |
Austrakia
Post Number: 4 Registered: Dec-07
| Posted on Tuesday, January 22, 2008 - 11:24 pm: |
Tks Benny i will get the receiver checked out. |
Post Number: 14511 Registered: Dec-03
| Posted on Wednesday, January 23, 2008 - 12:26 am: |
No worries, mate. Let me know how it turns out. I am curious myself. |
