Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > S-video or 15 pin pc connection
Author Thread: S-video or 15 pin pc connection
Username: Heckelsmiller
FL
for viewing dvds would I be better off hooking up my Dell lcd tv 30" monitor via the 15 pin pc connector and using the Dell 4600 MCE 2004 PC to play it or as a direct connection through a dvd player?
I would think the PC but I wasn't sure if that "dumb downed" the signal somehow.
Username: Feot
Texas
Post Number: 21
no, yes
you the same Heckelsmiller (Key West, FL) who was kicked off of eBay and yahoo for auction fraud?
you can run but you can't hide, eh?
Home > Message Board > Home Theater > Home Theater Setup & Planning > Archive through September 08, 2004 > S-video or 15 pin pc connection [ « Previous ] [ Next » ]
